Mixing 2x 3200mhz with 2x 3000mhz RAM?
I have 2x 16GB of 3200mhz of ram at the moment. Will getting another 2x 16GB 3000mhz instead of 3200 affect system performance or compatibility since it is slower? I can get the 3000mhz about $60-$70 dollars cheaper than the 3200mhz, so if it doesn't affect performance I thought I'll save some money there.
Does that also mean the 3200 will be running at 3000 instead?
I'm running an Intel 9900k build, and mostly do video and photo editing if that matters. No Gaming.
You would want to run all four DIMMs at the lower frequency + higher timings of the two.
For an example:
  • DDR4-3200, 16-18-18-40 timings, 1.35V
  • DDR4-3000, 14-14-14-36 timings, 1.35V
You would want to run them at DDR4-3000 16-18-18-40 timings, with 1.35V DRAM voltage.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
For an example:
I'm guessing I'll have to change that in the BIOS? Is this essentially overclocking the RAM to make it match the 3200?
That is underclocking it.
Higher timings = slower.
Will I run into compatibility or stability issues if I leave the 3200 RAM as it is?
No you are underclocking it to match. Slower performance. I would just look at getting 3200 again, itll save a headache.
EDIT: Did not see @Enderman's post above. Same thing.
Yes you will see issues if you don't underclock it.
Maybe, maybe not even that is possible because of the load on the Memory BUS.
"Hell is full of good meanings, but Heaven is full of good works"
The computer will probably change the frequency and timings automatically, so no you can't just leave it as is.
If it's the same RAM (same manufacturer, looks etc) like one being DDR4 3000 CL16 and the other 3200 CL18 then there's no problem since it's the same RAM.
Kingston has some HyperX Fury modules like that. Many manufacturers do. the modules would adjust automatically.
But if it's a totally different RAM, everything might work OK but also there might be many issues. That's why it's best getting the same RAM.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
