Does Philips still make quality monitors?
LightParticle
I been asking about monitor choosing in my country local IT forums about Philips monitors. And all three times I get answer like this:
Don't to harry to buy Philips monitors, because brand "Philips" has been sold to the asian's (China probably IDK) so don't expect high quality from them
is it true? false? As I know Phillips earlier was really good companies with high quality productions. Now its not? :)
In all honesty, nobody makes quality monitors anymore. The vast majority all have terrible black and grey uniformity, even the most high end models.
Even those advertised as 240hz capable run panels that simple dont have the pixel response speed (<4ms 'real' 100% transition speed) to keep up with a 240hz signal.
For panel uniformity if u rate them 0 to 10, 10 being the best, top end TV's like those that use OLED, hit 10, cheap TV's ~£400 can even hit 8 and 9's. 8+ resulting in good uniformity. The best score monitors achieve is ~6.5 with most being below 5.
So i wouldnt worry to much about any particular brand being bad, i highly sugest u simply check reviews an any monitor that catches your eye, preferably a reivew that actual uses display tests for resposne times, input lag, uniformity and the like.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
As I know, Philips and LG are made in the same factory.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
4 minutes ago, SolarNova said:
For panel uniformity if u rate them 0 to 10, 10 being the best, top end TV's like those that use OLED, hit 10, cheap TV's ~£400 can hit even hit 8 and 9's. 8+ resulting in good uniormity. The best score monitors achieve is ~6.5 with most being below 5.
So what is the major difference between TV and Monitor? Maybe we should buy TV's and plug this stuff to PC?
Primary use, and thus the specific things the manufacuters look for during QA. With TV's obviosly uniformity is important, especialy black uniformity due to the amoutn of time the TV ends up display dark scenes in movies and the like. if a whole family is watch a movie and the uniformity trash, they wil lall notice it and the Tv will end up back at the retailer.
Monitors on the other hand usualy get viewed by a single person, who will usualy be using it for work, or gaming, with less time to concentrate of uniformity concerns most go either unnoticed, or people simply dont care. So the manufacturers can get away with sending out crap panels.
You can most certainly use TV's as monitors, the problem with TV's though is size, anything below 55" is considered 'low end' so you wont find any high end 40" TV's, the 'good' TV's in regards to color, viewing angles, black levels, contrast, features like FALD etc etc, are mostly confined to 55"+.
This leaves only a very small handfull of ~40" TV's that are any good. You need one with low input lag, fast pixel response (since most are VA), and ofc uniformity and the like. ATM off the top of my head i recall samsung have a couple and Vizio having some,, but thats it.
TV's also tend to be limited ot 60hz and dont have adaptive sync technologies.
