Computer is unstable and hard drive use is locked at 100%
1 hour ago, soulreaper11207 said:Check the disk health first. Reboot the machine into your recovery environment. Scan the drive that windows is installed in by using disk part to list the Volumes, exit disk part, and then use dir driveletter for each volume. The one that lists the windows folder is your boot/primary drive. Then take that drive letter and plug it into check disk: chkdsk /r driveletter. This will flag and try to recover any bad sectors on the drive. Once it is complete, Reboot. Then at your log on screen, click the power button, hold shift, and click restart. Once you get the Choose an Option, select Troubleshoot, Advanced, Start-up Settings, and Restart. This will give you a start up settings page. Press 5 key. Windows will then restart into Safe mode. Once logged in, go grab Adware, Hitmanpro, and the free kaspersky scan tool. Run these. If the don't find anything, open up your system config app, change the boot settings to Selected start up and uncheck the start up items, and then reboot. If you dont see any issues after this, more than likely you either had a bad sector or a greed start up program. But If this is still having issues, you might have to refresh your installation of windows.
I found the issue to be the drive itself. Used a cloning utility to copy the files onto a temporary drive which took about 2.5 hours. Everything works good now! Planning on purchasing a Samsung 970 evo m.2 drive for the long term. Thanks!
