HELP! Zotac 1080ti Amp! Extreme PSU 750w 80+Silver
Reicarlow
So this is my current specs with gtx 970 MSI and I will be replacing it since I bought a used 1080ti. However,  I have a psu of FSP Raider 750w 80+ silver. I'm not sure if it would hold up the 1080ti??
Yes it will hold up!! would appreciate if you could put in more details like
Storage
Cpu cooler
Fans
In General 750 watts should hold up
Storage
Cpu cooler
Fans
Unless he has like 20 drives or a case made of fans, then the wattage use is insignificant.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
im using the raidmax augusta case which has uhm 3 fans itself.
CPU Cooler - Coolermaster Seidon 120v
Storage -  120gb SSD / 2 1TB HDD
Ram - HyperX dd3 1600mhz  2 8gb
(Planning to upgrade my ram also to 2600mhz)
So what do you guys think?
I would highly recommend getting a better quality PSU than that for a GTX 1080Ti.
The one you have is very poor quality.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
27 minutes ago, Reicarlow said:
What do psu do you guys recommend?
That's a high end GPU, you need something that will actually run it and protect it.
Seasonic Focus Plus
EVGA G2
Corsair RMX
