How to disable ChkDsk for and HHD
Gunn
Okay soo i doing some work on the laptop when a messege came up and wanted me to restart to do an chkdsk, soo i restarted the check disk started 1 minute later it laptop has already started.
A message came up saying that my hard drive was unaccesible (Denied access) soo i had to change the security to have access to my hard drive again. And i use primocache with a 32 gb ssd caching maybe thats why i had this problem
It's always running chkdsk for the disk? Are you sure the disk is OK?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Yes the hard drive is fine i had run hd tune multiple times but its fine
Hard Disk Sentinel says everything is ok?
okay let me install it
It says it okay performance 100% health 99% and smart looks fine
Then repair windows.
This might help;
http://www.mediafire.com/file/4s31u10j42qr2i1/GTribe_WinFix_by_191x7_v05.09.18.bat/file
30 minutes ago, Gunn said:
I already have access to my hard drive. my question can i disable the automatic scan for such hard drive
The drive should not be scanned automatically, that is not a normal behavior you should be trying to disable - focus more on why it's happening and how to fix it.
the hard drive is brand new it has a total 20 days of power on time https://gyazo.com/0e95e11357be056b68746785ba09bc52
You are still ignoring what I'm telling you. I'm not telling you the drive is broken. Windows or some other program is broken. It might even be the RAM memory. You need to find what it is. And stop quoting me, I've lost my will to help you with this matter.
