I have the stock cooler for it at the moment but i am wanting something quieter as it can get rather noisy when under use. The temps are fine when under use but i just want something near silent
I was looking at this https://www.amazon.co.uk/gp/product/B009VV56TY/ref=ox_sc_act_title_1?smid=A3P5ROKL5A1OLE&psc=1
Any suggestions?
https://linustechtips.com/topic/1041787-best-cooler-for-my-i5-6500/
What is your budget?
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
if you have some extra room and your main concern in noise, I would suggest a dual or triple fan all-in-one. They'll need to run much slower to dissipate the same amount of heat.
Just another engineer posting useful hardware videos directly to the interconnected network (AKA the internet)
Tech enthusiast. Check my channel out here https://www.youtube.com/channel/UC6FU1nfeGBBnw_bvHgWCqTQ
I hadn't noticed OP chose an AIO. It seems as noise is OP's main concern, so I wouldn't go with an AIO at all, but instead with a quality air cooler, which will perform similar to an AIO and be quieter.
I will look at a dual/triple i should have room for this i currently have an NZXT S340 Mid-Tower case
1 hour ago, Jordanhpal said:
Budget is not to much of a concern providing it is not pointless overkill. Anything around the £90 would be a comfortable amount to pay i feel
In that case, do you care about looks? If not, I would go with a Noctua cooler. These ones might be a good idea:
The NH-D15S is just like the NH-D15, but with one less fan, for higher RAM compatibility, in case you have tall RAM.
Any of these options will provide good performance (the more expensive, the more performance) and be very quiet, especially if you decrease the RPM of the fans, since you're only cooling a Core i5 6500 and the last two options will be great for overclocking, should you upgrade to an overclockable CPU in the future. Given that you have the budget, I would go with an NH-D15, however, if you care about looks, you could go with something like an NH-U14S and slap one of these fans onto it, to give it a better look, for a little over the price of an NH-D15.
Thank you, i do intend to upgrade my CPU in the future so future proofing with it is not a bad thing.
That would be overkill pricing. For locked CPU, you are looking at £30 price range.
To overclockable one? Or just i7?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Perfect ! Be sure that at the same clock, noise will be much lower with multiple fans
7 hours ago, bruny06 said:
These are all overkill. A 92mm cooler would be about as quiet for lower cost.
The H55 isn't very quiet.
@Jordanhpal What case and ram are you using?
