Do i need to replace my CPU Cooler?
vjizzle2384
So i moved my PC on to a table now and it has more room to breathe,  My CPU is Ryzen 2600x with a CM 212 Evo,  i realy a Stress Test via AIDA64, stressing the CPU, FPU and System Memory for about 13mins.
My question is if i replace my cooler to a beefier one like NH-D15 or DRP4 will i see any changes in temps or about the same?
This is my results with my Room at 20C.
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
The D15 is a monster of a cooler and will perform miles better than the evo can do
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Maxing at 78 under full synthetic load like that seems like you're probably fine.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
You don't have to, thermals right now are fine.
Desktop benching:
If you have good case airflow, good mounting pressure, half decent toothpaste, one of those coolers will lower temps quite a bit.
Not really.
Because of voltage curve the next 0.1ghz jump will either take more voltage than the D15 can safely dissipate (<85C) or become dangerous for the CPU's lifetime (1.4v+) compared to the 212 evo. Thus you will get the same performance on both coolers.
The clothes will be moved
My PC:
My Kids PC:
21 minutes ago, hello_there_123 said:
Not really.
Temperature wise.
Read the post
Just now, hello_there_123 said:
His temps are already fine.
Yep
I agree
will you intend to clock higher? if yes, temp put a fan in push & pull to see if it helps.
My cm212 fan was very weak and fixed by adding even with intel stock fan
 Screw it I’m just gonna save up money for monitor because the monitor I have right now is old but 10 years the highest resolution you can do is 1440×900.
It looks horrible I’ve been playing on my 4K TV it looks really good on that TV, only problem is I have turn in v-sync and locks it to 60FPS or I’ll have tearing.
My PC:
My Kids PC:
