my monitor has no signal with my pc
echy
my monitor has no signal with my pc?
why? what wrong?
everything is plugged in correctly but for some reason nothing is working perfectly
You're not even going to tell us your specs? Lmaoooo
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
I was gona suggest that maybe the tiny people that live in the monitor were on a lunch break.
so i have one display port in the motherboard plugged into the monitor
then i have one hdmi plugged into the monitor to the motherboard
then the monitor plugged into an wall outlet with a regular power cord
its so weird because the computer turns on.. it just has no signal(the monitor)
Why are both cables plugged in?
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
well i initially had it plugged both in, idk why. the monitor had a signal until i turned off the pc and then it turned it back on and no more signal
7 minutes ago, StewySphinx65 said:
Use a DisplayPort and connect it to your monitor via the Graphics Card if it has a DP port. Or you could use a HDMI if it doesn't have a DP connection. Only use 1 cable though not 2, unless you use more than 1 monitor
i have tried that. i even switched the monitor output setting to the correct setting(wether it was display port or hdmi 1) i still get no signal. this happened when i first got the parts .. and somehow i was able to get a signal and i just left it as that...but i accidentally bumped the loose psu cord to have the computer turn off. then i turned it back on and the monitor says no signal now... this
Reseat the cables? Both power and connection.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
i tried that as well, right now i have both monitor and motherboard set only with cables on display port and no other cable. i unplugged and plugged both cabels and rest pc.... still no signal with monitor.
Do you have another monitor to compare with?
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
2 minutes ago, StewySphinx65 said:
Have you tried a different cable to the 2 you have already. When I built my pc I ordered a DisplayPort cable off of Amazon and it worked for 2 week before failing, but my HDMI cable I use for my xbox showed that it was the cable that was faulty.
You said the computer turns on, do all the fans spin, is the GPU and motherboard connected properly, just check all the connections to make sure they aren't loose.
yes all the fans spin, the psu fan spins, the gpu fans spin, everything is on. i used the cables it came with
nope i probably use upgrade. i know the problem is the psu cable always being loose or the monitor cabel that connects to the wall outlet being loose aswell. its either one of those two. or the way i plug it in..the cabels which is dumb because it was working right after i turned off the pc.... i dont know what to try next, any suggestions
If they're loose, how come you can't just push them in so they... aren't loose.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
i can push them in, but they are still somewhat loose. i have a 4k lg monitor with a ryzen motherboard..and a good one to. so i dont know why this is happening. i need to test it with another monitor and see if its the monitor itself
That's what I would recommend.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
