Am I going wrong with a 550W PSU for this build?
Obbama
For my build which kind of PSU should I get?
I'm about to buy Seasonic Focus Plus Gold 550W Full Modular (since its at a discounted price at my local shop), would 550W be enough for my build or would I be better with a 650W one? Thank you!
Type
Item
CPU
Motherboard
Memory
Storage
Video Card
550 is fine
tho there have been some problems with seasonic the last while, but that only really applies to the v64 and 2080 ti
What does PCPartPicker tell you when you load up those parts?  It does have an estimated full-watt draw calculator built in when you make a build.  It's likely saying something barely over 300W for that.  You're fine.
edit: put it in partpicker, I was that close, neat.
That's a good choice for the PSU.
But what about the motherboard choice? I wouldn't go with that B450-A board with a Ryzen 7 2700X because of the rather weak VRM-s.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
550W is absolutely plenty, but the Focus is known to have issues with some GPUs. Might want to check out some other options
https://www.techpowerup.com/249838/seasonic-focus-plus-psus-encounter-gpu-compatibility-issues
It looks like it was limited to an ASUS GTX 970 Strix, and Vega 56/64, so with an RTX 2060 he's likely fine.  It was limited to few GPUs and shielded PCIe power cables fixed it for those that did have it.  No reason to spread FUD about buying an otherwise perfectly good PSU (when GPU's ripple stays in spec and doesn't exceed standards)
It is confirmed to have issues with those GPUs. That doesn't mean it's guaranteed to work with all the others. And if there are other options that don't have that issue, but are otherwise equal, why get the Focus?
