I7 9700k stock speed heat issues
So I'm having what seems to be a slight thermals issue with my non OCd i7 9700k CPU. I have reseated me Corsair H100i Pro RGB cooler to make sure this wasn't the issue. The pump is plugged into the CPU fan Header and based on other forums I set it to PWM full speed with minor improvements on heat. I read that lowering the Vcore can vastly improve temps but I cannot find that setting at all in my Asus Maximus XI hero (Wi-Fi) MB. All I can find is info on the Asus AI OC tool. Is this tool actually useful? I'd like to OC but not if I'm already having some heat issues. It will jump to the Mid 60s while playing Far Cry 5. And the Prime 95 will cook the cramp out of it with reaching 100C within a minute or 2.
I'm also running a RTX 2070 on a new 1440P 144hz monitor, but these issues were happening before my monitor came.  Is there anything I'm missing inorder to bring these temps down?
Parts:
PCPartPicker part list: https://pcpartpicker.com/list/ykJCQZ
Price breakdown by merchant: https://pcpartpicker.com/list/ykJCQZ/by_merchant/
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor  ($418.99 @ Amazon)
CPU Cooler: Corsair - H100i PRO 75 CFM Liquid CPU Cooler  ($79.99 @ Newegg)
Motherboard: Asus - ROG MAXIMUS XI HERO (WI-FI) ATX LGA1151 Motherboard  ($275.98 @ SuperBiiz)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 Memory  ($229.99 @ Amazon)
Storage: Samsung - 860 Evo 1 TB 2.5" Solid State Drive  ($147.99 @ Amazon)
Storage: Western Digital - Black 6 TB 3.5" 7200RPM Internal Hard Drive  ($229.69 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card  ($469.99 @ Newegg)
Case: Corsair - 270R ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: SeaSonic - EVO Edition 620 W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($39.99 @ Newegg)
Monitor: Samsung - LC27JG50QQNZA 27.0" 2560x1440 144 Hz Monitor  ($309.99 @ Amazon)
Total: $2257.59
Generated by PCPartPicker 2019-03-02 11:47 EST-0500
what p95 version are you using
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
29.4 I believe
Mid-60s in gaming seems normal.
Everyone says just use 26.6 because the newer version is too hot
I don't bother with it and just use A64 and ASUS Realbench, as well as actual workloads.
Try those tests and see what your temps are.
Ok thank you! I'm at work now but will post my results this afternoon
5 minutes ago, shoejam said:
29.4 I believe
don't bother with prime, it puts my 5ghz avx oc to 105C, but i can play division 2 beta at 80% load at 75C. that game will put a 9700k on full load and run it hotter than fc5, give it a go imho, or realbench, cinebench, aida64 would work too, cinebench actually resembles max gaming load quite closely.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Thanks for the tip. I'll try cinebench this afternoon. What temps should I be aiming for?
Anything under tjmax is fine.
Personally, my comfort level is under 90. After my delid, none of my testing goes past 81 or so, with a mediocre cooler.
personal preference, 75-85C seems to be fine for most.
Oh wow. Maybe I have nothing to worry about. That seems high to me. I guess I should retitle the post to "how to make my comp a refrigerator?" lol.
Unless you have a runaway thermal issue, your cpu will throttle or shutdown to protect itself long before damage occurs.
Keep an eye on your vrm temps as well, try to keep under 100 to prolong life
Update:
So a few things, I noticed that when I updated my BIOS, it set the "boost" mode or whatever Asus calls it to enabled. Once I turned this off and ran the older version of P95 (26.6) and the other test methods you guys recommended, nothing went over 52C. Usually hovered around the 40s. And that was after about 15 minutes. So it seems like it was a mix of A. My BIOS changing without me realizing it, and B. Not using the right tools to test my CPU. Thanks for all the help guys I really appreciate it.
Tools used:
RealTemp as my heat monitor.
CPUz stress test
Prime 95 version 26.6 (I did both small and large FFTs at default settings.
Cinebench - all the tests they had on there.
RealBench.
Thanks again guys. I hope this thread helps someone else in the future.
29.4 is AVX workload and will get your CPU hotter than anything else unless you run a high-load AVX workload on a regular basis.  26.6 is more regular load, you will probably never see temps as high as that unless your games use all the cores.
I will say this, don't trust any one test to see what your stability level is.  I've had OCs pass an hour of AIDA64 Stress Test then fail elsewhere, and I've seen others say they've had settings fail after passing Prime95 for over 8 hours.
Also, don't use RealTemp or HWMonitor for temperature monitoring, if you want temperatures as accurate as you can get them (it typically reads directly from thermal monitors on the motherboard), use Hardware Info 64.
Save up to 10% on eVGA.com purchases, use my Associates Code: 47AQQ6KPU2IZNXY
My system on ModRigs: https://www.modsrigs.com/detail.aspx?BuildID=42686
Primary Rig:
CPU: AMD 5950X at 4.65GHz 1.275V - Mobo: Asus Crosshair VIII Hero - PSU: eVGA P2 1200W
CPU Cooler: EK Quantum Velocity Block (480mm XE Radiator with push/pull EK Vardar D-RGB fans)
2 x 16GB G.Skill Trident Z Royal 3600MHz CL14 RAM (14-15-15-35-1T at 1.45V)
GPU: eVGA RTX 3090 Kingpin Hybrid - Core @ 2160MHz @ 1068mV, VRAM +1000MHz
Case: Thermaltake View 91 - SSDs/HDDs: Too many to list; Samsung 980 Pro 1TB & 2TB M.2s, Samsung 4TB SATA SSD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
