Fractal Design Meshify S2 thoughts
Go to solution Solved by tarfeef101,
I think they've improved the mesh compared to their last generation, but overall for an "airflow" case the double filtering on the front panel is still rather restrictive.
That being said, fractal's interior design has always been a pleasure to work with, and will make your build process easy (and flexible).
I personally prefer "flashier" or more interesting cases that have a bit more flair these days, but that's just me. I started out with a Define series case as my first, so I can see the appeal. I actually used meshify cases for a couple client builds a while back. They were nice and discreet for an office environment, quiet, and had enough cooling capacity for the hardware they needed. So they definitely have a place.
Hi all
I was looking at the new Fractal Design Meshify S2 case and was wondering what other people's thoughts were on it. Even if you don't own it, just want to get your opinion. Are there other cases that are better but have same features? Is the C version better?
Any and all thoughts and recommendations would be great!
Case: https://www.newegg.ca/Product/Product.aspx?item=N82E16811352103
https://linustechtips.com/topic/1039621-fractal-design-meshify-s2-thoughts/
Consider watching some of the reviews of the case done by tech youtubers. I would think that a low amount of people have it right now since it just got released.
It's hard to compare it to the C version because the Meshify S2 is more based for water cooling with the bigger insides made for custom loops.
Based on what I see between the two cases (S2 and C), they both have good airflow and good quality, it's just each case is better for different applications.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
It's an R6 that became an S2 that became an S2 Meshify.
Since I have an R6, I echo @tarfeef101 in that they're a joy to work and build in.  I love the aesthetic as well.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
I like the ventilation on the S2 and the size, but personally, I would prefer something a bit more impressive to look at. The reason I am asking about the S2 is because I was looking at potentially get it, but its a tad, plain at least for me.
Yeah, I have watched a couple reviews on YouTube, and I like the case , looks easy to work with, good air flow capabilities.
Do you think there are better cases on the market at the moment that are equal in features and quality?
I only build in Fractal cases as they are always have enough room and features for my needs and those I build for.  the also have excellent customer service and the key parts can be easily replaced if there is a problem.  I had a defective HDD light on the front panel of a Fractal Core 5000 and they got me a new one.  More recently, I needed to add a new drive to my Define R5 and realized that when I was cleaning up my work room I had thrown out all the unused drive sleds.  They just wanted my case serial number and postage and sent the new drive sleds I needed.
Workstation PC Specs: CPU - i7 8700K; MoBo - ASUS TUF Z390; RAM - 32GB Crucial; GPU - Gigabyte RTX 1660 Super; PSU - SeaSonic Focus GX 650; Storage - 500GB Samsung EVO, 3x2TB WD HDD;  Case - Fractal Designs R6; OS - Win10
I have never owned a Fractal case, but they sound like a great company, that make great cases. Leaning to get one.
You need to get one cuz:
I'm Josh, you're Josh, and Fractal Josh...
I think it's fate.
OnePlus Ecosystem:
Other Tech:
