What Graphics card to run a 240hz Monitor G Sync
TaiPC
I don't know if I'm asking the right question, but I was wondering what requirements do I need to run a 240hz g sync monitor? I'm a PC newbie, so I don't know much, thanks for the help!
I don't know if you need the right graphics card or the right processor.
A 240hz g-sync monitor comes at 24" 1080p.  You will need a 1080 GeForce card or a RTX 2080.  With these cards you will also get free AA which you can turn on in the nvidia panel.   So the 1080p wont show nasty jaggies.  Also you get to set the game settings to their highest.  Also depends what game you play.  If you play CS:GO then all you need is a 1070 or 2070.  But if you want to play at a lower resolution like 1600x900 you can get away with a RTX 2060.  Also like I said before it all depends on what game your playing.  Some will not yield you 240fps and some will easily do so.   As far as CPU, you can get the 8700 or 8700k for 300 dollars and there will be no bottleneck.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Almost any modern GPU with an output that can provide enough bandwidth can drive a monitor to its fullest.
If you're asking what it would take to run games at 240 FPS to make use of that refresh rate, a high-end CPU with strong single core performance and a higher mid-range GPU if you don't mind dropping the details and resolution down. If you're asking for what it would take to drive 240 FPS with maximum details at the native resolution... well  you might be looking at an absurd amount of money for the hardware.
4 minutes ago, Turtle Rig said:
What resolution do you plan on playing at ?
Well there aren't any 240Hz monitors on the market with a resolution of over 1080p (at least on PCPartPicker).
What's your budget (if any)? What games will you be playing?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
There are couple choices and their 24.5 or 25" and cost 500 dollars and up.
Once again it matters what game he plays.  If he plays CS:GO then he can grab a 1070 and possible graphic settings tweaks he will get his 240fps but it will dip but that is where g-sync comes into play.
For 240Hz, you'll need a good graphics card and CPU. What are you working with right now?
Primary PC:
you need a monster of a cpu with the highest clock speeds for this to get a consistent frame rate anywhere near that 240hz realistically
I’d get the strongest card you can. Unless you wonna turn some things down.
Will also need a strong cpu. Mine sits at 90% on all cores in the two cpu intensive games I play. That’s only 150-180 frames. The card isn’t gonna do much more unless I turn stuff down.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
What free aa ?
-13600kf
- 4000 32gb ram
-4070ti super duper
1 minute ago, Ebony Falcon said:
What free aa ?
AA Anti Aliasing.  there are different methods of it in the nvpanel.  It means to basically get rid of the jaggies you see in a game.  The higher the resolution the less jaggies but the sweet spot is 1440p with all AA methods turn on and you cant see any jaggies.
For a game like CS:GO you can use a 1050TI and get frame rates in the 100+ at 1080p
PC Specs:
CPU: Intel Core i7 8700
GPU: MSI Armour GeForce GTX 1080 8GB OC
Motherboard: Asus-Prime 7370-A ATX LGA1151
RAM: G.Skill Trident Z RGB 16GB
Cooler: Noctua NH-U9S
Case: Kolink Observatory RGB ATX Mid Tower Case
100 would be the minimum. Kinda low level.
yes i know what aa is but usxing th methords in the nv panle still use resorces its not free lol
-13600kf
- 4000 32gb ram
-4070ti super duper
I have done a test, turning off all AA ,, and playing game,, then turning all the methods ON , in nv panel,, and there is pretty much no hit on the frame rate.
You'll need the BEST single core performance you can get your hands on, and overclock the hell out of it. At frames this high it is most likely going to be determined by your CPU not your GPU.
I would invest in a 9600k/8600k/9700k and overclock it past 5ghz.
Also i would recommend at least a 2080 or 1080 ti if you want to hit those frames with decent settings in most games.
Current Build
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
  • 10 months later...
Hi, saw this post just now, how about this build?
i9-9900k oced to 5ghz
z390 mobo
GTX 1070
16gb corsair vengeance 3600mhz
Will this be having consistent 240fps on Apex legends with all Low  settings? Thanks! I just needed to make sure before i buy a 240hz monitor, cause trying to play competitively
  • 1 year later...
