Help: PC fails to boot with display on GPU.
Go to solution Solved by AGoodSword,
thats so weird that shouldn't be happening... it could be a BIOS option i know on my board it'sa  older intel one they have option auto and i set that to The PCI-E lane or Nvidia it says one of that
Hi guys,
My computer recently kept booting on to the on board built intel graphics instead of my 1080ti, until i press the reset button for once or twice, what could be the issue ? Should i switch my graphic card's PCIE Lane?
Build:
MOBO: ASUS ROG STRIX Z390F
CPU: I7-9700K
SSD:SAMSUNG EVO860 M.2 256GB
RAM: GSKILL RIPJAWS 16GB 3000MHz Dual Channel
GPU: ZOTAC AMP EXTREME 1080Ti
Hard Drive: WD BLACK 2TB
PSU: Thermaltake Toughpower RGB 850W(80+ Gold)
just saying i have never seen a pc that you can use your Intel hd with through your GPU Output makes 0 sense
Just now, Espire said:
Hi guys,
Build:
CPU: I7-9700K
unless it's a laptop
What do you mean booting on the onboard graphics? Have you connected your monitor to the back of the 1080ti?
Quote or tag me @Lemtea so I can see your reply.
PSU Tier List
DAYBREAK: R5 5600X | SAPPHIRE PULSE RX 6700XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | Win 10
FIRESTARTER: I5 760 @ 4.0GHZ | XFX R9 280X DD | 8GB RAM | CRUCIAL MX500 250GB SSD | OCZ ZX 1000W | CM 690 IIIWin 10
KEYBOARD & MOUSE | CORSAIR STRAFE RGB (MX RED) | GLORIOUS MODEL D | STEELSERIES QCK XXL
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
That my initial thoughts too but when it goes to windows and i check on the device management, it does not detect my GPU
Yea onboard graphic I've connected my monitor to my gpu but it shows pitch black and nothing came on
Have you connected the pcie power cables to the gpu? Is the gpu in the top x16 pcie slot (closest large slot to cpu)?
PSU Tier List
I shall try that anyways i just hate it when i need to plug another hdmi cable to check on my other monitor..
Yes i have
When the system turns on the rgb and fan on the gpu are working but jus no display
1 minute ago, Espire said:
Yes i have
What psu do you have? Do you have another gpu and power supply that you could test?
PSU Tier List
Im using a thermal take 850W modular(gold), unfortunately i dun have any spares available
that should be more then enough
Whats more is that it doesn't work if i just restart the PC i have to Reset via the Reset button for it to post to the GPU...
is there anything else i can do before i could determine that this GPU is dead for sure?
Put the GPU in another system.
PSU Tier List
Ok, this is weird i went and swap out my Power Cable to another one reformated the PC and disable the Onboard GPU and its now working fine... Thanks though everyone for helping.
