Gigabyte Aorus Z390 Extreme Help
GMart84
Long story short I had to change my MB again, the MSI Z390 Godlike that I picked up had an issue where whenever XMP was enabled the first slot GPU always ran at PCIE 3.0 2x never more, off XMP it ran at 8x in the SLI setup as it was supposed to.  MSI support told me there is likely something wrong and that I should return the board as it had only been a week.  While at the store the sales folks convinced me to move to the Gigabyte Aorus Z390 Extreme at it would be better for Overclocking and less buggy.
To say I am struggling with the Bios is an understatement, I have managed to get everything enabled and clocked right, I can now get the 9900K to hit 5.4 GHz at a vCore of 1.39v and stay in the 80s so the capabilities of the board seem to be a little better than the MSI and significantly better than the ASUS Maximus X that I had been using.  Now I am looking to get my everyday OC in place at 5.1 GHz at a vCore of 1.285v which shows up as 1.296v in HWinfo64.  However the voltage never goes down and I cannot find a place in the Gigabyte bios to set adaptive voltage or offset.  It just seems to want to be a manual number and that is it.  Am I missing something?
Thanks for your time.
BLACK and BLUE Build
i9-9900K - 5.2 Ghz @ 1.305 vCore, 32 GB Corsair Vengeance RGB Pro (@ 3200 Mhz), Gigabyte Aorus Z390 Extreme, EVGA RTX 2080Ti XC Ultra, Samsung 970 Pro, Samsung 970 EVO, Dual Custom Loop Cooling, Thermaltake Tower 900, AX1500i
VR Build
i7-8700K - 5.1 Ghz @ 1.36 vCore, 32 GB G.Skill TridentZ RGB (@ 3200 Mhz), Asus Maximus X Hero (Wi Fi ac), 2x EVGA GTX 1080Ti SC Black Edition, Toshiba NVME, Custom Loop Cooling, Thermaltake Core P5, HX1000i
FreeNAS Server Build
Pentium G5400, 8 GB Kingston HyperX Fury (@ 2400 MHz), Asrock H370M-ITX/ac, Intel 320 System SSD, 4x Hitachi 7200K 4 TB HDD, Thermaltake TR2 650W, Cooler Master Master Liquid Lite 120, Bit Fenix Prodigy
Daughter's First BuildCore i3-6100, 16 GB Corsair Vengeance LPX (@ 2133 MHz), Asrock H270M-ITX/ac, XFX RX-580 GTS, Custom Watercooling (Both CPU and GPU) 2x Corsair Force LS, PowerSpec 550w, NZXT H200i
I think Gigabyte calls their offset voltage "dynamic voltage" or DVID.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
@BobVonBob I see that, in the bios, it is greyed out unless I choose Normal for vcore, and then select and -0.150 offset.  Get into windows and the vCore is now showing 1.41v for CPU which is a little high I believe and so I then took it down to -0.250 as the chip runs perfectly at 1.285v set manually, but then it won't even post.
VR Build
