PSU recommendation for 8700k and 2080 [OC]
Hello,
I'm building my first pc, this is what I have (I' ll overclock):
-MSI z370 gaming pro carbon
-Intel I7 8700k (delid)
-Asus RTX 2080 Dual OC
And I'll get:
-2x8GB DDR4 3000/3200
-500GB 970 evo/pro
-2x3TB HDD
What PSU would you recommend me?
I was thinking 650W/750W, I'm leaning toward the Corsair RM850x (it costs the same as the 650 amd 750 at 120€), what do you think?
Thanks!
2 minutes ago, Crunchy Dragon said:
RM850x is a pretty good unit, a little bit overkill for your uses, but a good choice nonetheless.
Yeah I know it's overkilled, what would you recommend at 650/750W that may be cheaper?
Thanks
Thanks
A 650W unit would be perfectly fine. You could alternatively look at the EVGA G2 and SeaSonic Focus Plus Gold units, any of those 3 options is a solid and reliable PSU.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Thanks
RM750x?
RMx units are Tier 1. Lower wattage units are usually cheaper than their higher output brethren, and 750W is a solid wattage.
Bitfenix formula gold 550/650 is a good option.
Primary PC:
3 minutes ago, Crunchy Dragon said:
RM750x?
Unfortunately 650, 750 and 850 RM x all cost 120€ in Italy
If they're all the same price, why not get the 850W?
They all 3 cost the same. At this point the RM850x looks like the better deal
I think I prefer a modular PSU for cable management.
Probably the one I'm going to pick
How is it possible that the RM1000x costs only 8€ more than the 650x?
As already mentioned by others, 850W is unnecessary for your system.
If it helps, for your system with an 8700K + RTX 2080, even with overclocking (5GHz on CPU) you would still be under 500W, probably closer to the low-mid 400W end of the scale. Less if you're not overclocking the CPU. So based on that I'd aim for a good quality 550W PSU, such as the RM550x since you're already looking at the RMx units. Not sure which European country you're in, but the RM550x (2018) can be had for around 90 Euro. https://de.pcpartpicker.com/product/bqVD4D/corsair-rmx-2018-550w-80-gold-certified-fully-modular-atx-power-supply-cp-9020177-na
If you're in Europe then the Be Quiet Straight Power 11 550W is a good choice at around 95 Euro.
The Bitfenix Whisper M 550W is around 90 Euro and would also be a good pick.
One problem is that the RMx units use a single rail design so with a higher wattage unit if something goes wrong, it can go very wrong before OPP trips to shut down (compared to a 'safer' multi rail system with OCP on each rail which will shut down sooner/at lower values). Though, whether or not this is a real concern you should be worried about... ¯\_(ツ)_/¯  (I run a RM750x and I'm not concerned)
Another thing to consider is that on *some* higher wattage PSUs, the fan will run at a higher RPM and be louder. Though, that really depends on the individual units in question, and AFAIK all of the RMx series of PSUs are very quiet anyway.
Though the benefit is you do get the extra PCIe & EPS connectors/cables with the RM750x and higher wattage. Which is nice.
Edited by Spotty
Store selling them probably bought a heap of them during the mining craze when everyone wanted high wattage PSUs, and now after the bitcoin crash has a bunch of high wattage units that no-one wants to buy, so is dropping prices to clear them out?
Manufacturer rebates [provided to the seller]?
Discounts & specials?
There's also two versions of the RMx series of PSUs. The RMx and the RMx (2018). So pricing may vary slightly between the two different series.
¯\_(ツ)_/¯
What country are you buying in? Do you have a link to the store(s) you're looking at?
Using Coolermaster psu calculator it says my load wattage it's 569W with OC on the cpu and gpu
Italy, Amazon Italy
So it's really ~450W then.
Coolermaster PSU calculator (Outervision) is not accurate and will overestimate by at least 100W. It makes money by recommending PSUs and providing affiliate links to go buy the PSUs it recommends. Higher wattage PSUs have higher profit margins, so it will tell you that you need a higher wattage PSU just so they can make more money from you.
I just put in an i3 8100 - No other parts listed - and it gave me 173W for just the CPU alone.
Pentium G4560 by itself? 165W according to Cooler Master PSU calculator.
They just add 100W on top of what the CPU actually draws in order to convince you to buy a more expensive, higher wattage PSU.
Italy, Amazon Italy
Hmm, okay seems prices in Italy are a little bit higher than Germany (where I was taking my prices from earlier).
Looks like the RMx units you were looking at are the older, longer RMx units, but that doesn't really matter as both the RMx and RMx (2018) are good units. Might explain why pricing between the different units is a bit inconsistent though.
Looking at prices, the Bitfenix Whisper M 550W and the Straight Power 11 550W are showing as 120 Euro on Amazon Italy. So the RM550x for 103 euro would be my pick of the bunch. Though if you did still want the RM750x/RM850x instead for whatever reason then it doesn't really hurt having more wattage than you need and you're still getting a good quality PSU. You do get extra PCIe and EPS cables with the RM850x if that's important to you.
Yeah MSI psu calculator gives me 470W.
The thing is: are you sure I'm gonna be fine with 550W? I don't want to have the psu alway running close to 100% to save 20€.
What about corsair TXM series? They are significantly cheaper, what do you think about them?
Thanks
What about corsair TM series? They are significantly cheaper, what do you think about them?
Thanks
The Corsair TXM ? If so then that is also fine.
Yes that one, the TX650M it's at 89€ compared to 120€ of RM850x and 127€ of RM1000x (I know it's wayyyy overkilled, but for the same price I'd rather get something that most of the times runs fanless and at the best efficiency and that I won't never change if I'd ever need more power in the future).
What changes between the TXM and the RMx other than one is fully modular and the other semi?
Do you think being fully modular it's worth the extra 30/37€? (I've never built a pc so I don't know how much the semi modular impacts cable management)
Thanks
Thanks
Too loud.
What about Bitfenix Whisper M? 650W model would give you more PCIe and EPS cables, so even that unit makes sense, unlike some other 650W PSUs on the market
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
6 minutes ago, Quadriplegic said:
Too loud.
It's 96€ in Italy. Would you pick this compared to the others? (Check my comment above yours to see the prices)
Thanks
Thanks
Would 140% pick it over TXm, especially given €7 difference.
Would I pick it over RMx? Hard to say. Whisper would be more than enough for your unit and you would still have headroom for 2080 Ti.
Ex-build:
Meshify C – sold
Thanks
If the Bitfenix Whisper is only 7 euros more then go with that. As mentioned by Quad it is quieter overall. Only thing I don't like on it is the bulky 24 pin cable but not really a major issue.
If 650W it's more than enough for a i8700k OC and a rtx 2080 OC and all the rest (and I'm 99% sure it is), I'd definetely get the whisper and save 31€. I don't need 850w, neither 1000w (other than running most of the time fanless), so I see no point in spending more where I can get the same thing for 31€ less.
Am I right?
btw thank you guys for the support!
Yep 650W is enough ?
