What's The Difference Between GIGABYTE Z390 Pro Vs Elite?
Solved by -rascal-,
The Z390 Arous Pro is the higher-end board between the two.
The Pro version has support for nVidia SLI / AMD Crossfire, and also has more USB 3.1 ports.
There are also a couple more little things, including:
- More fan headers
- Temperature sensor headers
VRM design are exactly the same for both boards.
TECHNICAL GAMER ·
Posted in Troubleshooting1 -
GOATWD ·
Posted in Graphics Cards4 -
3
4
remo233 ·
Posted in Graphics Cards7 -
Jackie55 ·
Posted in Troubleshooting10 -
Aussie_Avo ·
Posted in Cooling9
