Direct connecting desktop and laptop on the same network
WarmasterCain55
what is the proper way to connecting two computers to each other for file transferring? They are both on the same network and crossover cables are a thing of the past but i can't figure how to make the systems see each other.
Are they connected to the network via Ethernet?
Ryzen 7 1700X - Cryorig C7 - Gigabyte Gaming B450 Wifi - 16GB GSKILL Aegis DDR4-3000mghz - WD Black NVMe 250GB M.2 / WD Black 2.5 1TB HD - Gigabyte Radeon RX 580 8GB - FD Node 202
"Never trust a computer you can’t throw out a window."
— Steve Wozniak
PCPartPicker - Steam - GitHub
Just now, WarmasterCain55 said:
Yes.
Have you turned on network sharing in the file explorer?
— Steve Wozniak
Sorry for the late reply.  Network discovery is on on both devices.
Edit, ok i am a bit of an idiot.  My laptop can see my desktop but my desktop can't see the laptop?
No idea why that is, but can you pull off whatever from the laptop to the desktop, or does that not fix the problem?
— Steve Wozniak
