Search In
  • More options...
Find results that contain...
Find results in...
Overclocks for a RTX 2060
RoyceNZ
 Share
Hi All,
Quick question. I just purchased a GeForce RTX 2060 and have tried my first GPU overclock.
I used MSI Afterburner and followed some youtube videos on how to use the OC Scanner.
The Core Clock is now set to "Curve" and I set the memory clock to "+1000", and fan speed to auto. The power limit and temp limit were also set to max. And I did nothing to the core voltages.
So in BF5 I get nice frames, in the 70's for the most part at 1080p. I am running this on an i7 2600k @ stock (waiting on a Dark Rock Pro for CPU overclocking)
So my question is that ingame, BF5, I get 2020MHz on the GPU clock and 8002MHz on the Memory clock, all while staying under 70Degrees C.
Does this sound ok to everyone? Have I stumbled into my first oc'ing gracefully?
Thanks for any and all advice.
7 minutes ago, RoyceNZ said:
Hi All,
Yes 1000Mhz is achievable and you did that.  The core at 2020 has a slight overclock.  Your not going to gain much from the core but the VRAM of 1000Mhz more will yield good results.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Thanks for the reply Turtle Rig
Would you suggest I push the Core higher? Even try manually setting the core? I've never done it manually before but dont mind learning.
Your not going to get much more and it is just not worth the extra heat thus fans spinning faster.... You gain most from the VRAM OC and you already took it pretty much to the max for that card.  Anymore and you might get instabilities.  The core I would be happy with 2050Mhz.  some people can get theirs to 2200Mhz but that 150Mhz extra does nothing compared to what hte VRAM OC does.
Awesome reply man thanks, exactly what I was looking for.
Cheers Turtle
 Share
