Audio buzz from faulty PSU?!
Go to solution Solved by Dantoshou,
16 hours ago, 191x7 said:
AGC (Automatic Gain Control) might be causing you issues, or a microphone boost set too strong.
Also, since you mentioned noticing electricity while touching the microphone/interface, I would check the grounding pins on the power strip. I've seen bad power strips having some voltage on the grounding.
I forgot to mention I've just changed the power strip over, might also be time to invest in a brand new one with surge protection insurance etc etc.
Hi guys bit of an odd one right now!
So yesterday I was using my PC noticed that my condenser mic (Rode NT1-A) and audio interface (Tascam US-144) were both receiving an electrical current that could be felt when you touched your hand to them, not a static shock but a constant current.
I realised this wasn't normal and discontinued use straight away, tried different power cables etc with the interface and then decided to take it apart and inspect the damage
Upon opening I noticed a burning smell on the board and the unit now no longer works, I will now be taking it to be recycled.
What's strange is that I have another problem to do with the audio on the pc now, namely, whenever I run any game on the pc, there is a really loud buzzing sound, it appears linked directly to the microphone (guitar hero usb mic) as it stops when the mic is unplugged.
I'm wondering what this could be, I first thought the PSU might be the issue, from what I can see the 12V rail is at 12.8 5V rail is 4.8 and 3.3V rail is at 3.2 I'm not an expert on these things but previously I had a faulty PSU that when checked with a multimeter was outputting 10-11V so I'm not sure this is anywhere near as bad.
This is a problem for me as I can't talk to friends while playing apex legends or even when I'm playing crackdown 3 solo, I can hear the buzz if I have listen mode on the mic (which I tend to do as I like the audio feedback of hearing what I've said so I know I'm not peaking or breathing into the mic accidentally)
TL:DR external soundcard blew up, using different mic which is making strange buzzing noise and sounds terrible when running games.
Example here
Crackdown 3 with audio issue
Any help would be much appreciated!
https://linustechtips.com/topic/1035377-audio-buzz-from-faulty-psu/
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
is the buzzing literally audible or is it just the microphone input, or can you hear it through your headphones while the mic is plugged in and listen mode is off?
it could just be the microphone kicking the bucket/not being of high quality
maybe move the mic away from EVERYTHING if its possible? like get an extension and move it away from your pc to see if it still makes a noise
CPU: i5-4690k @ 4.4 GHz | RAM: 12GB DDR3 1333MHz | GPU: Sapphire Pulse RX 580 4GB
