Building Our Own CPU Water Block?!?
How hard can making your own water block be? Actually not too hard if you have a CNC Router... Also really hard when you have a Linus...
CAD: https://lmg.gg/WaterBlock
Buy Single Flute Bit.
On Amazon: http://geni.us/nAxR
Buy CPU Water Block
On Amazon: http://geni.us/QQAVw
On Newegg: http://geni.us/9ADQ
I love these videoes that you work on Alex... That's probably because I'm going into MechE, but I'm sure lots of the audience likes it too regardless.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
now these are the vids I like
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
If you want the acrylic to become clear after machining just flame treat it.  It's easy and you get instant glass effect.
Buy CPU Water Block
Have you considered using a basic copper heatsink as the base of the waterblock?
You'd have to shave down the fins to a more resonable height, and trim around the edge to give the plexi top a surface to mate with, but it would get around the issue of trying to cut ur own micro fins / channels.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Now that you are CNCing your own water blocks, whats stopping you from watercooling directly to the CPU's heatsink? Like a hole in the waterblock, allowing water direct contact to the CPU heatsink. Idk if this is feasible, but could improve temps and remove the need for thermal paste!
Its very rarely a good idea to flame polish acrylic. Melting the surface introduces stress into the material that WILL cause cracking eventually. You would be much better off polishing with Novus polish with a hard felt cloth. If you must flame polish then you need to anneal the part to even out the induced stresses.
Here's a tip for when using taps.
When creating new threads, you should first use a taper tap. These cut more gradually and thus make it easier to get going, then finish with a bottom tap. There are also plug taps, bit those aren't needed here.
System specs:
4790k
GTX 1050
16GB DDR3
Samsung evo SSD
a few HDD's
haven't watched the video yet, but based on their air cooler DIY videos, i fear for the life of the motherboard and CPU
This. But you can make it more simple by using the original heatsinks as your block base.
Trimming the height may be the most difficult part of it. I think I would use a belt sander in the direction of the 'slices' or how do you call those things in English, finns? Anybody?
wbk3APBLawiRguvCvyyxeiAqEDXTKAyYYhW9FMN-
The loop at the back is not scaled properly, but you get the idea....
This is a Xeon socket 771 1U cooler by the way.
Great video guys, I loved it.
No signature found
This is correct but from the specifications of G1/4 threads used in water cooling fittings the threads have a not as standard 55deg included angle rather than the more typical 60 deg found in ISO and ANSI machine thread specs. Because of this its possible that they were not able to find a full set of taps like you have shown. Also when tapping a hole all the way through piece of stock its typically not necessary to bottom tap. Just run the tap all the way though to the end of the threads on the tap. As long as the material is thinner than the full formed thread section of the tap you will have full form threads all the way through the material.
From the video though it looks like they were using a plug tap (that's perfectly fine) they just needed to give it 3-4 more turns to get the full thread to the back side of the acrylic.
Thanks, I didn't know that about g1/4 threads.
If you open with a taper tap, then you should also bottom tap. The taper tap doesn't cut threads as deep and screws sometimes don't fit properly.
System specs:
4790k
GTX 1050
16GB DDR3
Samsung evo SSD
a few HDD's
If they come in a set of three, taper is usually not marked, plug is marked with 1 ring and bottom is marked with 2 rings.
No signature found
If the threads on the fittings are based on piping thread.. they are tapered intentionally.
Can Anybody Link A Virtual Machine while I go download some RAM?
That is only sometimes true G1/4 threads are based on BSPP (British Standard Pipe Parallel) making it a straight thread similar to a machine thread. There is also an ANSI standard called NPS threads that are straight as well. You find them on fittings that rely on a method of sealing other than just the thread interface itself.
Nice to see Henkel products in the wild!  :D 454 baby!!!
"And I'll be damned if I let myself trip from a lesser man's ledge"
When polishing, start with sanding. If you start with the final step you'll end up with a shiny piece of material that isn't flat.
Depending on how coarse (do I spell this right?) the piece is, you can start with 320-600-1000 wet sandpaper. Depending on how fine your polishing paste is, you might want to take it up to 2000 grid. Then polish it in two steps with 5000 and finally 12000 for that shiny effect. I use this method on headlights very frequently in my shop.
When I have to make something flat, like a cylinder head, I tape the sanding paper to a piece of glass. No double sided tape, just duct tape on the edges.
Then I move the cylinder head on this surface in figures of 8.
No signature found
"We don't need to drain the loop." Yeah, heard that one before; last time Linus got water all over his motherboard. I can't believe the editors didn't add a piece of that video there.
Is it just me or do all the videos with Alex's DIY projects turn into Linus cringing sessions?
What is actually supposed to go here? Some people put their specs, others put random comments or remarks about themselves or others, and there are a few who put cryptic statements.
My ¢2: For the red, you would probably be better off using something more along the lines of a cold plate. A cold plate would be lower profile and could have no seams inside, so no leaks. You also have the option of a press fit in a grove, soldering to a flat plate or thermal epoxy to a partial grove, each with advantages and disadvantages. Typical cold plate:
My first thought would be to use a thin walled stainless tube, given the space constraint (also mcmaster has a lot of options), pressed into an aluminum block(s) (probably with a little thermal epoxy, as press fits can be a bit tricky).
It wasn't nearly as bad as the last few videos, but very unimaginative. They basically made an extraordinarily simple water block that managed not to leak and got shitty temps out of it. Also they just CNCed everything, so they very likely just downloaded the plans online.
I just don't get it.... would it have been hard to cut slots in the middle at half depth (compared to the o-ring groove) for more surface area? What about literally scratching it with a razer blade. It is only copper after all. The lack of imagination out of that crew is.... stunning. You could have done so.... much.... interesting.... stuff. If I had access to that equipment I'd be able to build you dozen different waterblock ideas just off the top of my head.
For examples: Variables you could change in a controlled manner.
  1. Surface area exposed
  2. Volume of water chamber above copper
  3. Effects of flow (sideways water entry or top water entry?)
  4. Designing channels that promote good (or bad) water flow.
  5. Copper plate thickness. What's the limit before you get concave bending due to the pressure?
  6. How about a spiral design cut into the copper, with another copper sheet on top. Water goes in through the middle, has to travel out through the spiral, then over top of the top copper cover, then out of the plastic housing?
So, so many ideas. Is it just lack of imagination?  Or lack of skill in CAD? Or what?
Actually people have designed a waterblock that replaces the IHS (integrated heat spreader, not quite a heat sink) and LTT reviewed it
https://youtu.be/n4O_Dq3xRJA
Primary PC:
Would a gasket maker work instead of an o-ring?
Please quote me so that I know that you have replied unless it is my own topic.
I built my own water cooler in high school using a vertical milling machine. (Non CNC)  Similar design.  The copper I used was a 2 pound bullion bar from Provident Metals.  The back plate I cut out from plate aluminum.  To seal it I used Permatex waterpump and thermostat RTV silocone.  I have been using the block in my system for years now without any issues.
