I need help. I need a camera.
Well if you are looking for an overall good piece of kit for this sort of thing, a Panasonic G7 coupled with a fast standard prime should be good enough for interviews. Maybe a go pro for a different angle, and a 24-120 equivalent for estabishing shots etc. I think you'd be ok with that, but it will require work on your part with lighting and focus etc.
Now, there are other options, For instance a used a7sii might be a better option, coupled with their cheap 50mm 1.8, but overall it would cost more than the panasonic.
The best you can do probably is a fuji xt3 with the kit lens and a 35mm f/2 or just get a cheap manual focus prime like a 50/85/100mm and adapt it. Another possible option is a used 60mm f/2.4 Macro, which will be great for interviews and maybe shots of stuff of his etc.
