ASUS Prime-B450 Plus Stuck on first boot and other problems
17 hours ago, Dully said:Tried. not working. BIOS is on latest version.
The Reviews I read wasnt that bad but I had not much budget and it was way cheaper than other boards on a sale by my reseller
I installed a fresh Windows 10 because I changed to an System SSD, so I had a clean system when I assembled the new PC
I will try to manually set the RAM Speeds! Because this is my first DDR4 system, is there any different to DDR3 OC?
Not really, but I recocommend following a how to as it will require some additional understanding of whats going on.
Here is a guide on overclok3d: https://www.overclock3d.net/news/memory/how_to_manually_set_up_your_ram_speed_timings_and_voltage/1
and another good read right here on linustechtips forums:
