Raspberry pi question: CSI and DPI port use at the same time?
6 minutes ago, OJTheAviator said:Hi,
I'd like to use my Raspberry Pi camera module with a display hat. The camera uses the CSI connector/interface, the display uses the DPI connector/interface. The product page for the display says that "it uses just about every pin on the Pi", and I'm wondering if this would affect compatibility with the camera module. Any insight would be greatly appreciated!
Thanks
(P.S. I wasn't exactly sure where this post would fit, but I thought the subject still fit within the forum's content range. Sorry if this is in the wrong spot.)
CSI still can be used. What they meant was that it uses every normal PI gpio. Meaning it would be hard to connect anything else over them. The CSI and DSI interface should be unaffected.
EDIT:
As long as there is still room for the Camera connector to be plugged in with the screen also plugged in.
