Dead pixel on monitor what should i do
BurntNewt
Should I replace it, get a different monitor or keep the one with the dead pixel.
https://www.bestbuy.com/site/hp-25x-24-5-led-fhd-monitor-gray-green/6280605.p?skuId=6280605
that's the monitor I have now. the dead pixel is pretty noticeable but other than that I like but idk whether I should get a better panel or resolution with keeping the response time and refresh rate and if i should is there any suggestions that are around 200 USD
There's good 144hz monitors @$200 USD. If you can RMA and have the patience for it, go right ahead.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
If you're within the return window, take it back to the store. If you're not, then you might be stuck with it. Manufacturers generally won't replace a whole panel via RMA for a single dead pixel.
Aerocool DS are the best fans you've never tried.
thats what im gonna do but idk if i should exchange or get something different
There's nothing particularly wrong with that monitor. You just got one with a dead pixel. Now, if you didn't like the monitor anyway before noticing the dead pixel, then that's a different story. There are plenty of 1080p options at Best Buy around $200, and a 1440p Acer panel if you want a higher resolution.
