RGB LED strips pollution
22 hours ago, TheCynicalCris said:Hi,
I've been trying with a few models of LED RGB strips but to my surprise, they pollute FM signals like crazy. Only my tuner connected to the external antena works properly when RGB is on, other three FM Tuners (all Technics branded) on indoor antenas receive a lot of pollution. Why RGB strips pollute so much on FM signal?
A constantly changing current level trough a conductor causes it to radiate electromagnetic interference. They use a PWM square wave to control the light intensity/color of these LED strips. Square waves are a nasty waveform, EMI wise, because it contains a broad spectrum of frequencies up to very high frequency (harmonics). This, in combination with the fact that these strips and their supply wires are probably about the right length to make excellent FM radio antennas (+- 3meter/1.5 meter), is the cause of your FM radio interference.
This is why you often see arrays of ferrite beads or some other high frequency filter devices near I/O connectors on computer boards, etc. You'd want to keep the surface of your HF loops small and thus keep them off of (long) wires.
