Will a SATA to USB 3.0 Adapter work on this optical Blu-Ray drive?
Solved by .Apex.,
it says on the bottom that it doesn't support CD-ROM, you need one that comes with an external Power Supply
also you can connect the SATA and SATA power on your PC and leave the Bluray just a bit outside your case temporarily, there's nothing wrong with that.
shadii ·
Posted in Troubleshooting0 -
1
Sleepy_gamer_boi ·
1
KageSong ·
Posted in Programs, Apps and Websites1 -
Regnoc ·
Posted in Networking2
