Need Help with old CRT Monitor
username1
Go to solution Solved by username1,
It's fixed! All I did was slightly lift the back of the monitor.
anyone know why? So, I can prevent it from happening again.
I found an old crt monitor (Samsung SyncMaster 793s) so, i decided to hook it up and play some old school games. It was working really well all afternoon, until the screen turned yellow (I took pictures for compression) but the menu still looks normal. Don't know a lot about electronics, is there a problem with setting or might need to get it fixed.15468044228711295536927.thumb.jpg.3c77c2f9e20ce052a42bf0a1fa02be09.jpg
you could try to work around a bit in the color settings, but that would be it softwarewise... tried swapping or even just reseating the cable?
First thing I did was reseat the cable even cleaned it and the VGA cable is attached to  the monitor, tried playing around with the colour but it still looks yellowish.
yeah, then it might just be the panel... I would wait for some other user's before getting a different one, but it might be eol
btw, why did you mark it as solved?
I didn't knew which button was for reply and clicked it by accident, it's my first time on any forum and thanks for trying to help.
