Search In
  • More options...
Find results that contain...
Find results in...
Seagate BarraCuda 2TB 3.5-Inch (ST2000DM006) Spin up sound.
EyeOfTheLiger
 Share
Is the little beep right before the whirr of the spin up normal?  These are similar to what mine is making after accessing them after not using it for about 2-3hrs (most of the files/progs i use are on my SSDs)
the beep and spin-up sound is fine. You should only really start to worry if it makes a rattling/cracking sound when it spins up.
Always remember to backup your files :)
 Share
