Search In
  • More options...
Find results that contain...
Find results in...
Devices in PCIe slot 2 not being detected
Insprill
 Share
Go to solution Solved by Swes,
Try removing everything and add a card to the 2nd slot only and see if you can pull picture out of it then try again with 2 cards and no capture card then finally ad the capture card.
Also reset CMOS....
Hello! After a CPU upgrade, any device that i plug into the 2nd PCIe slot isn't detected. I have graphics card in the first 2 slots, and a capture card in the 3rd. I removed the capture card thinking it might be the amount of PCIe lanes, but the gpu still wasn't detected. If you guys could help that would be great!
Specs:
-i7 7700k
-Gigabyte GA-Z170SLI rev 1
-2x 1070ti
-elgato 4k60 pro
Is it still forcing your first graphics card to run in 8x mode?
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
Also reset CMOS....
 Share
