Search In
  • More options...
Find results that contain...
Find results in...
Need help with cooler for my build
Geeva
 Share
this is what i have currently i just need help picking a cooler for it i have a budget between $80-$115 for one
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor
Motherboard: Gigabyte - B450 AORUS elite
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage: Western Digital - Blue 500 GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - GeForce GTX 1060 6GB 6 GB SC GAMING Video Card
Case: Cougar - MX330 ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA G3 850 W 80+ Gold Certified Fully-Modular ATX Power Supply
The stock one? Otherwise the Deepcool Gammaxx 400/GT, Cryorig H7 or Arctirc Freezer 33 esports one will do.
btw get a better board and some case fans. If you drop to a 550w PSU you might be able to get a GTX 1070 as well.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
I agree 850 watt is overkill , hyper 212 evo done or just keep the stock one......................
why is this mother board not good this is the one when i first started build everyone recommended
also i was going to go with 850 because im having a new one gifted to me
then too bad all those people dont include one overclocker. This board is fine if you're running stock and don't plan on CPU upgrades that draw more power.
Desktop benching:
i dont really plan on upgrading this is gonna be my main computer for awhile i will mostly be playing lol and vindictius but if you were to recommend a board what one would you use
gammaxx 400
212 evo is a bad choice
-It's very noisy
-Gammaxx 400 and CRYORIG m9a are both much quieter and cost less for the same performance
-This is what installation looks like: https://imgur.com/a/qCRwPdW
 Share
