Search In
  • More options...
Find results that contain...
Find results in...
Integrated IO shield doesn’t fit.
Khalma
 Share
So I’ve been trying to install my mobo but the IO shield doesn’t fit in the hole. I try but the top standoff screws won’t fit.
Lots of I/O shields have a bit of foam padding that makes the initial fit a bit tight. Just apply some slight pressure to make the holes and standoffs line up and screw the board down.
PC Specs - AMD Ryzen 5 5600X MSI B550M Mortar 16GB Crucial Ballistix DDR4-3600 @ CL15 - RX5700XT 660p 1TBGB & 256GB 600p Fractal Define Mini C CM V550 - Pop!_OS 20.04
 Share
