Search In
  • More options...
Find results that contain...
Find results in...
How long for Prime95?
How long do you run it in small fft to see if your OC's are stable?
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
I don't. I run it to see if my thermals are in check. To test stability, I rely on RealBench.
Sincerely,
me
5 min for a light test, 10-15 mins for a solid result but more than 15 mins it's wearing down the hardware.
My PC is a fast boyo:
6700K - 32GB - 1080 - 256GB EVO
^^You don't need more info than this right?^^
2 hours ago, Gix7Fifty said:
1hour p95, 1 hour blender, prime small fft for max temp (careful on this one), blender for everyday temp.
I can't run fft on 5.2, but i can on 5.1
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll evga non-3090 tie ftw3 1905 0.8v 65C 270w (double fps of 1080ti) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666  bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA non-30 tie XC 1830//7600 0.85v 210w ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon dying) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
  • 2 months later...
I know this is like a 2 months ago but how do you stress test on realbench? Do you do benchmark or stress test. If it is stress, all you have to do is put the amount of gpu ram you have in the memory slot?
Thanks!
 Share
