Search In
  • More options...
Find results that contain...
Find results in...
Atx Motherboard suggestions for first pc build
This will be my first pc build and I’m seeking some suggestions and guidance on my build. Forgive me if this is not in the right forum either. Here is some basic run downs on what it requires and the case it will be going into I appreciate the help with suggestions. This will be a gaming pc.
Socket: 1511 [i7 8700k 300 series]
Case: Cooler Masters H500P Mesh
Case I/O: USB 3.0x2 and 2.0x2; audio in and out
Do you want to overclock?
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
I’d like to explore and experiment with that in the future. I choose a case that would allow me to utilize a top mounted 360mm rad which I will be attaching a closed loop cooler master rad to my cpu initially.
 Share
