Search In
  • More options...
Find results that contain...
Find results in...
Black vs white heat spreader RGB contrast?
I'm upgrading my system soon and I'm I'm looking at the Corsair Vengeance RGB (non PRO version) RAM and I have a choice of either black or white heat spreaders. I'll be using an Asus Prime Z390-A motherboard which has white heat sinks, so in terms of colour matching, the white RAM would look better, but would the black heat sink might offer better contrast with the lighting?
Part numbers:
Black - CMR16GX4M2C3200C16
White - CMR16GX4M2C3200C16W
Opinions?
white rgb ram typically offers better reflections and hence brighter colors. I'm somewhat confused as what you mean by contrast for rgb, sorry
colour has nothing to do with reflections!
Contrast in terms of how how well the lighting shows up on the ram. For example if I had a black heat spreader, and set the lighting to white, then it'd show up better, whereas if I had a white heat spreader with white lighting it wouldn't show up as well if that makes sense? Not 100% sure if contrast is the correct term to be honest.
reflections may not have been the best term, but white shows color better than black.
if you're only going to use white rgbs, black may be better. But for other colors, the white ram will make the colors appear more vibrant. The colors from the rgb will make white ram appear to be the colors displayed from the rgb.
black may make the colors stand out a little more, but white ram will make the color appear stronger and fill the case better. Especially if your motherboard has white heatsinks, you may as well match right?
That's a good point, I'll go with the white then, thank you! :)
This is art point of view perspective match anything you do to your liking.
I love Salvador Dali and maybe you like Picasso :)
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
 Share
