Search In
  • More options...
Find results that contain...
Find results in...
I've got like 2 problems with my Dell Inspiron.
Bonzilink
 Share
Go to solution Solved by Derrk,
13 minutes ago, Bonzilink said:
I've got a Dell Inspiron 560 that I'm going to turn into a 1080p PC build. But I got some problems with it. I can access the BIOS and boot screen just fine. But when I just let it boot normally, it just keeps rebooting to the Dell logo all over again. I thought it was a corrupted Windows installation, so I downloaded the OS recovery tool and entered the service tag. But it wouldn't let me enter it as it was "invalid". I need help...
I would just reinstall windows altogether. If you have another computer, just find an ISO file for whichever version you're using/want to use & put it on a flashdrive. If you can get into bios fine, you should be able to boot into the flashdrive and reinstall it
Bonzilink
Mhm. I will buy a flash drive and get on that.
Bonzilink
 Share
