8-Pin ATX and one 4-Pin ATX connector CPU
You can find power supplies that have 2 cpu power cables, one that's EPS 8 pin and one that's 4+4
For example, my by now old Seasonic X-650 has such a cable arrangement
Here's some psus that have 2 cables:
100$ (30$ off) CORSAIR RMx Series RM750x CP-9020179-NA 750W - https://www.newegg.com/Product/Product.aspx?Item=N82E16817139233
100$ (60$ off) EVGA SuperNOVA 850 G3, 220-G3-0850-X1 - https://www.newegg.com/Product/Product.aspx?Item=N82E16817438092
105$ Seasonic FOCUS Plus Series SSR-750FX 750W - https://www.newegg.com/Product/Product.aspx?Item=N82E16817151187
130$ (105$ after 25$ mail-in rebate card) Seasonic FOCUS Plus Series SSR-850FX 850W - https://www.newegg.com/Product/Product.aspx?item=N82E16817151188
110$ CORSAIR RMx Series RM850x CP-9020180-NA 850W - https://www.newegg.com/Product/Product.aspx?Item=N82E16817139234
110$ EVGA 750 GQ 210-GQ-0750-V1 80+ GOLD 750W Semi Modular - https://www.newegg.com/Product/Product.aspx?Item=N82E16817438060
and others...
I'd go with the Corsair RMx series 850w, then the Seasonic 850w one , then the 750w rmx , then evga GQ series and last the g3 .
