Using Significant Amounts of Ram When Idle
Solved by IAmAndre,
If the RAM is used by Windows-related processes, it makes sense because Windows tends to scale its RAM consumption based on the system's needs. Basically it will reduce its RAM usage when your programs need more RAM.
kacper6768 ·
Posted in Displays1 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies0 -
1
RagePoweredGamer ·
Posted in Troubleshooting12 -
14
Cookiey ·
brau508 ·
Posted in Troubleshooting1 -
Syponj ·
Posted in CPUs, Motherboards, and Memory1 -
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
