CSGO running at 1 fps on good hardware
Jim1h
I have a inspiron 7577 and I want to play CS:GO but the cpu is maxed out and the game runs at 1 fps but then when i alt tab it runs at normal framerates until the game is selected again and im not sure what to do
Specs:
i5 7300hq
Gtx 1060 max q
128gb ssd
1tb 5400rpm hard drive
8gb ram ( I think ddr4 2133 )
You could launch the task manager to see if your system resources are being used elsewhere?
They are not 100% csgo then they go back down to around 5% after the game is closed
Is there anyway to check that outside of the game because you cant select anything in the game
There should be a way to check your graphical settings for CS in-game
edit: Or do you mean that CS freezes up upon launch and don't have the option to select things?
nevermind i was able to get to settings and vsync is off
no still running badly 1 fps but it responds to clicks now
do you have any software that is trying to overlay on the game?
Like I have NZXT's CAM installed and if the fps overlay is enabled it locks up games
You could try cranking down the settings one by one until the FPS starts to rise.
Also if you are using a laptop, there should be a battery icon in your lower right corner on the desktop, you can go into those settings and change the battery setting to High Performance if it isn't already. That should push your machine a little harder.
The laptop is on high performance mode and i do not have nzxt cam installed or any software thats trying to overlay
Hmm.
I would try just to turn down settings one by one until the FPS makes a few changes. Beyond that, that is really all the info I can give.
Discord is installed but its csgo running at 100% cpu usage with no other application using more then 2% cpu
