Search In
  • More options...
Find results that contain...
Find results in...
Budget PC from used parts
haxxi
 Share
Hi Everyone,
I would like to build a pc for my friend, with used parts. I copied the thread starter questions to make it easier for me and to you.
1. Budget & Location
My budget is around 125k HUF (~450 $US, I am from Hungary)
2. Aim
He wants to try out new title games, but mainly gaming with PUBG, Rainbow 6 Siege, Fortnite and other games like this. Max resolution is FHD. We would like to save things from his old pc, he has 2x8GB of DDR3, a good Bitfenix case and a Zalman 600W PSU.
The things needed to change:
- CPU
- Mobo
- VGA
- SSD (does not have yet)
I have made a list with the things I try find:
- CPU: i5-4570/4590/4650/4670/4690 (no need for K)
- Mobo: Intel 1150, chipsets: B85/H87/Z87/H97/Z97 - Asus, MSI or Gigabyte (had some problems with a lot Asrock boards)
- VGA: Nvidia 1060 6G / 970 4G
- SSD: 860 EVO 250G or similar
3. Monitors
One FHD for the games, and a TV connected for the browser
4. Peripherals
no need to purchase
5. Why are you upgrading?
His old PC is an AM3+ based one with FX-6300 and GTX950. He has low fps with low graph settings and needs a little upgrade.
Are my list good? Do you have any recommendations to these ones? Or I can freely buy them?
Thank you for your time and answers.
Nandor from Hungary
For My guess, I would Like change into Intel 1150 into new (1151).
-Intel i3 8100 or Intel i5 8400
-Motherboard find good one lga 1151 (preferred product like Asus, Asrock, Msi
-Graphics card - Gtx 1060 6GB(Not VGA Wire, its used as HDMI)
-SSD- 860 EVO 250G
        - AMD Ryzen™ 5 1400 Processor
        - Asus Prime A320M-K ATX motherboard
        - Zotac GTX 1050Ti 4GB OC Edition
        - Kingston 8GB DDR4 2133Mhz Ram
        - Corsair VS 550 power supply
        - Kingston A400 240GB SSD
                                                       - 1TB WD BLUE HDD Hard Disk & Samsung 320GB HDD(7200RPM)
        - CPU COOLER: Stock Cooler(AMD)
-SSD- 860 EVO 250G
The DRAM prices are high, and he has 16G of DDR3. Finding a skylake based mobo with ddr3 is very rare, so thats why I want to stick to 4th gen Intel. Had one, and never had any problems with it. With your spec, the prices could be more expensive (+30%) and it does not fit the budget.
Grab a used dell optiplex or similar off ebay with a 4th gen core i5. Should be around 150-200$
Reuse the old PSU.
Grab an used R9 290x for about 100-120$
Keep the rest of the cash for massstorage or similar.
oh sorry, I didn't read carefully. for you mentioned, I would like to go higher model i5 ?  and motherboard z97,gpu 1060.
Reuse the old PSU.
Had that in mind, but the case he had is better, and wanted to save it, but I know that the optiplex has lower noise (I have a 7010 for media pc). Does the motherboard of that PC fits in the case? (I dont know if it is same as mATX or not). Does the cooler have the same mounting points?
I really do recommend an i7, quad cores kinda suck. Grab a B85 or H87/97 chipset motherboard, and you'll be set. A GTX 980 ti would be pretty good to get off eBay if you snag a $175 deal or something.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
It sadly uses an inverted formfactor
 Share
