How to fix headphone driver?
Laniakea
So these are Sony XB950AP's and for a quite a long time, the distortion levels are really destroying the quality of the music (I hadn't have them before). This special one is present at the left earcup and it shows itself at below 33Hz frequencies. It really sounds like a tractor... I cleaned it the best way I could but no luck, haven't even spotted anything yet even.
This is when the time has come to get new ones!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
ooh F...
But for real can I not fix this????? Hate to say this but I live in Turkey and economy is Fd up really they're expensive.
Okay I figured something out, some part of the diaphragm of the left earpiece is stuck to the bottom level when I compare it with the right earcup... How can I fix it? Is it planned obsolescence???
Hello, the driver on the left side of my Sony xb950ap's coil is stuck to the magnet, or something, as you can see in the video. What should I do? I don't want to get a replacement part as that will cost so much and I fixed every inch of this headphone myself. Any ideas? I tried pushing a stick from the back of the magnet, in the hole :D After quite a pressure nothing happened and because I can puncture the diaphgramh I stopped it. Please help this is quite urgent, no one helped for days...
