Need help with overclocking ryzen 1600x
14 hours ago, Boba Fett said:Hi,I recent got a new motherboard and cpu and wanted to know if anyone had set settings for the cpu as ive tried but it keeps crashing on cinnibench
Ive got the ryzen 1600x
Gtx 960 g1 4gb
8gbs ram
Thanks
8
I have the same CPU 1600x with 120T Deep Cool Game Strom cooler with Asrock B450 Pro4 mobo, 2x 8gb hyper x ram 2400 oc @ 2733 and I found the following overclocking to be good and safe:
So across all cores I am set to 4025Mhz the voltage is 1.38750v or you can add to 1.39250v its ok, but I have overclocked my ram too from 2400mhz to 2733mhz @ 1.35v but I have done the ram OC after I found this stable OC on the CPU, although if I lower the ram OC I can push the CPU to 4075Mhz with 1.39750v, The chipset on B450 mobos are very good and you can try this and I have 25-35 idle temps stable, and under full load on torture tests it goes to 67c with spikes to 75c but those are CPU calculations spikes, the CPU is maintained on 65c stable. If you have better cooling you will be very fine. If you don't have that a good cooling just back off the voltage a bit and test it with AIDA or prime95
