144Hz IPS Monitor advice
Solved by Origami Cactus,
That's the closest thing i found.
It is 1080p 24inch 144hz monitor, but it is samsung Qled (VA), not ips. It is certainly much better than TN, but not as good as ips. VA is more vibrant than IPS, blacks are darker etc, but viewing angles are worse. But it doesnt have the IPS downsides like backlight bleed, so each has their strenghts and weaknesses.
