Search In
  • More options...
Find results that contain...
Find results in...
Will my GTX 1060 fit?
Shiniontv
 Share
Hey guys,
I wanna buy a Ryzen 7 2700X with an Asrock X470 Taichi (non-ultimate), but will my EVGA GTX 1060 Gaming (Single fan) fit into the PCI-E slots, and what slots should I use?
Hope to hear from you guys soon
Thanks in advance,
Shinion
yes ofcourse, why wouldn't it ?
there is no should, theres a must, you must use the Pcie 3.0 X16 slot, aka the long one :)
Okay thank you xP
Just now, Shiniontv said:
Okay thank you xP
new to building? incase you might get the wrong one, heres a pic
altho i recommend a better gpu, a 2700x deserves a good gpu, whats your budget?
 Share
