best way to add keyboard backlight?
Solved by W-L,
1 minute ago, kelvinhall05 said:And you'd either have to stack PCBs which would get pretty fucking hard real fast or do some janky-ass circuitry that would probably render your keyboard unusable, if not completely broken.
I've seen some mechanical keyboards without backlight but on the PCB have spots for LED's but pretty sure they omitted the circuity for power and such.
2 minutes ago, gameboy3800 said:the keyboard has 2 usb ports i could use to power any mods requiring it.
The problem is not power but the ability to have the space to add in the lighting.
