Finished my 1st SFF Build
aeffertz
Case: Cougar QBX
Mobo: ASUS Maximus VI Impact
CPU: i5-4690k OC to 4.7 GHz
CPU Cooler: Corsair H60 AIO w/ Prolima thin 120mm fan
RAM: 16GB Corsair Vengeance
GPU: MSI Gaming X GTX 1080 Ti
SSD: PNY 250GB
HDD: WD 1TB
PSU: Enermax Revolution SFX 550W w/ custom sleeved cables.
Wanted a small 4k gaming box. Pretty stoked with how it turned out! Making the cables was tedious as hell but make a huge difference in this tiny case, looks and airflow equally! I want to ditch the HDD and get a 1TB SSD and replace the current SSD with an m.2 drive.
8288 in Fire Strike: https://www.3dmark.com/3dm/31490967?
Sexy, SFF FTW!
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
9 minutes ago, aeffertz said:
Case: Cougar QBX
SSD: PNY 250GB
HDD: WD 1TB
Damnnnn!!!
Did I fix your problem? Please feel free to donate to me at <Link Removed>
Any donation is greatly appreciated! Thanks!
My pc - PCPartPicker part list
Yeah, it wasn’t easy and I had to modify the case a bit to fit a radiator above the mobo and to fit the massive MSI 1080 ti.
Both the CPU and GPU run around the 60-70° range under load. I wish the mobo didn’t have the massive vrm heatsink, to be honest. It blocks about a third of the radiator.
  • 4 months later...
#speechless
It's simply a handsome build! Really well executed!
I can just stare at it whole day admiring..
I'm also working on QBX build currently, migrating from ITX tower.
I will do my best to get the best fit without taking any compromise with beefy air cooler in it. This will be my first and the most challenging build..
I was thinking to use that same PSU, but I got information about the Enermax Revolution SFX is not a good unit, but that side brand lettering gives it a really nice additional aesthetics which is one of the reason I want to use this PSU.
What do you think about that PSU so far you are using it?
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
  • 4 weeks later...
On 5/5/2019 at 8:33 AM, _Hustler_One_ said:
#speechless
Thank you! So far the PSU has been perfectly fine, no issues. I even have a pretty decent overclock on the GPU and CPU.
On 12/21/2018 at 9:52 PM, aeffertz said:
Looks good
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
  • 5 months later...
sorry for reviving this thread, but how on earth did you place the 1080ti in there? I have the same case planning on getting a newer graphics card for my RVZ02 build and chucking my 1070ti gaming x on the QBX case.
  • 5 months later...
Thanks for the inspiration on this.. I owe you a pint of beer, bro!!.. You're a champion!! :D
Hakintosh Build:
- Mobo: Motherboard Gigabyte Z390 I Aorus Pro Wifi LGA1151 INTEL GEN 9
- Proc: Intel Core I7-9700K Desktop Processor 8 Cores Up To 4.9 GHz
- RAM: Corsair Vengeance RGB 32GB 2x16GB DDR4 3200MHz
- GPU: XFX Radeon RX 580 GTS XXX + OC Edition 8GB
- Nvme: SSD WD Blue SN550 M.2 Pcie Gen3 Nvme 2280 500GB
- SSD: 1Tb Kingston
- Cooler: Corsair Hydro Series H60 Water Cooler
- PSU: Enermax Revolution SFX 80 Gold 550W
- Case: COUGAR QBX - Ultra-Compact Pro Gaming Mini-ITX Case
- Bluetooth: Orico BTA-403 USB Reciever
- WiFi: TPLINK TL-WN725N USB
New to the forum but both the OP and K4izoku are killing it! Very impressive and inspirational.
-Robert
Case:  Cougar QBX
MB:  Asus ROG STRIX X470-I GAMING
CPU:  RYZEN 7 3800X
GPU:  MSI GeForce GTX 1070 Gaming X
SSD:  SAMSUNG 970 EVO PLUS 500GB  3.0 NVMe
SSD:  ADATA SX6000LPN 1T NVMe
MEM:  G.SKILL TRIDENT Z 3600 C16 16 GB (2x8GB)
PSU:  FSP Dagger 600W 80 Plus Gold Certified Full Modular Power Supply
  • 3 weeks later...
Hello, I am planning on building with this case and using an AIO specifically the Corsair H60 as well. I just wanted to know, if you need to use a SFX PSU to have that aio on the top because personally I don't want the AIO hanging on the side panel.
Cheers!
hello O-R1C3,
  The OP used a SFX PSU and did a great job mounting a his H60 AIO over the CPU (see pic above). I would definitely recommend a SFX in the QBX to give you plenty of room to work. IMHO the side panel blocks the view of a job well done.
-Robert
Case:  Cougar QBX
CPU:  RYZEN 7 3800X
