Search In
  • More options...
Find results that contain...
Find results in...
air cooler for ryzen 2600x
 Share
hi guys, which one is good for my CPU 2600x Ryzen?
1. cryorig h7 quad lumi
2. cryorig h5 ultimate
3. cryorig h5 universal
can the universal or ultimate cryorig h5 be installed in my case? this is the link for my case http://www.coolermaster.com/case/mid-tower/masterbox-k500/, and whether from the three cpu cooler, can each fan be replaced? because I have 1 fan left from the masterfan pro airpressure cooler master thank you for your help and sorry if my english is bad
6 minutes ago, 17030644 said:
why no go with a 2600?
Bcs i think 2600x is 2600 with overclock, i buy 2600x bcs i dont want to overclock it (play with stock)
5 minutes ago, Happycowdance said:
the included one is good enough unless you are doing crazy ocing
Yep i know, bcs in this era, RGB is everything bro haha
So i want to replace that fan with my cooler master's fan
2600x's cooler has rgb????
if you are going to use an aftermarket cooler anyway then the 2600x makes no sense.
Overclocking on 2nd gen ryzen is fairly simple, just use PBO
Im not using that PBO, maybe i'm using xmp my RAM only,
Wait, so if PBO active on 2600 so it can match with 2600x?
yes
PBO ain't good on the 2600 lul
anyway a good cooler for the 2600 would be a CRYORIG m9a and Gammaxx 400
Yes, the fans can be replaced with any fans with standard 120mm mounts.
Any of them fit in your case and would be fine. The only difference between the H5 Universal and Ultimate is the included fan being slimmer for better ram compatibility. Why are you looking at these coolers in particular?
Yup bcs, i think only cryorig have better performance and aestetics in my country ahhaaha
So i can buy h5 series and replace that fan?
what's your country
Yes, they all support any fans with standard 120mm mounts.
Can you link us to where you're shopping?
 Share
