"General failure" times to times when i ping -t
Solved by Zorbio,
!!! ISSUE RESOLVED !!!
Well i wouldn't say "resolved" but more likely bypassed...
I just put my ethernet cable into a usb adapter (https://imgur.com/a/laLcsoP), i haven't been disconected since.
I still have a related question : Is the usb adapter using the same NIC ? Does my usb adapter have it's own NIC ? Or does my motherboard have two différent NIC (Like a secondary NIC for USB adapter) ?
