Search In
  • More options...
Find results that contain...
Find results in...
Does it fit? (☭ ͜ʖ ☭)
Mentos
 Share
Would the Dark Rock TF fit in the photios 250x? Maximum cooler height 155mm, thats it, couldn´t find any more info to that case, had to cheap out on something.
well what are the coolers dimensions
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
1 minute ago, SpiralTTGL said:
Max CPU Cooler Height Allowance
170 mm
It says 155mm for me, 170mm for the PSU length
170 mm
163 mm x 131 mm x 140 mm
they wouldn't give you a number on the psu its obvious it can fit any size with a mid atx
But does it fit? ?
170 mm
1 minute ago, Mentos said:
But does it fit? ?
170 mm
Where does it say that? Product page says 155mm.
Answer remains, though. Dark Rock TF is 131mm.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
 Share
