Search In
  • More options...
Find results that contain...
Find results in...
GPU usage drops to 0% while load is at 100%
FvLionGT
 Share
so when I put any sort of load on my GPU whether its a game or a stress test the gpu load drops to 0% shortly after the test or game has started and stays that way
the game drops to 1 fps and the gpu usage doesnt change at all.
Max GPU temps are at around 60-65C
Max CPU temps are at around 55C
I also checked the ram using the windows memory diagnostic and it has found no errors
I tried changing the GPU power limit to a lower or higher value but neither of them worked though after changing it to a lower value the gpu usage dropped to 0% faster than usual.
games tested:
bo3
bo2
cod4
bf4
gta v
specs:
I7 9700K
16GB 2400MHZ ram
MSI RTX2070
Corsair RM750 psu
Also when I try using MSI kombustor the same thing happends after just a few seconds and then the PC becomes almost dysfunctional and the gpu fans spin crazy fast for a minute or so until the screen turns of and then turns back on after a few seconds and then it works fine again
no they get to 65C at 100% for a split second and then the usage drops to 0% and the temps drop to around 40C
8 minutes ago, Dmeijer134 said:
I have a similar issue with a vega 64 and rm750x psu
can u explain exactly what the issue is?
so maybe we can try to resolve it
Gpu usage is inconsistent as hell in games drops from 99 to 80 and even dips into the 70%
When this happens the fps drops with it.
Power usage spikes too.
ohh so your problem is a little different from mine
in my case it just drops to 0% and it doesnt get back up
 Share
