radiator fans spec meaning
4 minutes ago, yotallo said:so if in the HD140 the static pressure and the CFM is higher then the ML140 which has much lower CFM and lower static pressure then for max performance i should go with the HD140?
Yep if noise is not a concern I would go with the HD140
By NICULL
Started
Posted in Troubleshooting1 -
By lemonhope135
Started
Posted in New Builds and Planning1 -
1
By JyroClassified
Started
By Matthew10550
Started
Posted in CPUs, Motherboards, and Memory2 -
By LoneStarfish
Started
By Frey yan
Started
Posted in Peripherals0 -
By Gothaurus
Started
Posted in Servers and NAS0 -
By Charmeleonnz
Started
